jet
#1 Posted : Thursday, August 1, 2013 5:39:51 AM(UTC)
jet
Was thanked: 36 time(s) in 34 post(s)
Hi.
vMix v10 should allow to create shorter Video Delays. Now the shortest time is 1 second (v10.0.0.55). For small delays vMix could maybe use RAM. It would be nice if user could choose from different "time sltyles":
New drop down list could have following "time styles"
-milliseconds
-seconds
-frames
and then the slider is used to set the desired value.
As a quick fix this could be done by allowing the user to manually enter the desired frame count (delay) value.
Buffer size (delay lenght) should also be adjustable after it has been created.
Kind regards,
J. Tervo
