lael
#1 Posted : Thursday, September 7, 2017 6:51:55 PM(UTC)
lael
@Martin @Tim
Can we get the specifications for the system being used for the funtime live shows please?
Which motherboard is being used - any comments on how it is performing, and what sort of render times are being achieved at 4k? Are you still offloading streaming processing to another computer running vmix as you did for your first 4K stream or are you now processing everything on the one computer (record at 4k and stream to 1080p?
lael
#2 Posted : Monday, September 18, 2017 7:46:05 PM(UTC)
lael
?t=15m28s - here are the specs...
redbeard
#3 Posted : Thursday, September 28, 2017 10:43:41 AM(UTC)
redbeard
It appears that the motherboard is actually a gaming 7 (I looked online and only found 3, 7 and 9 versions). I see a 7 on the box however.
What computer case are you using, and what power supply?
