jurajtoma
#1 Posted : Tuesday, September 5, 2017 3:18:59 PM(UTC)
jurajtoma
I have the following option, for CPU (other specs are same)
16 GB RAM
2 TB HDD (might do 240 SSD for OS + 1TB for media)
** NO GPU ** (using remote dedicated server)
Option 1) Intel i7-4790K - 11193 passmark
Option 2) Intel Dual X5650 - 11527 passmark
I would be running VMIX feeding to local WOWZA instance and transcoding to 720p and 480p H264.
My dilemma is I don't know if there is any difference, as far as video transcoding is concerned, between a single CPU (i7-4790k) or dual CPU (X-5650). What difference does it make, if any, and which of these two options would be recommended? There is no GPU helping in transcoding.
