Feature Requests
One button switch to another playlist
Joined: 2/2/2017(UTC) Posts: 8 Location: Balen, Belgium
We use vmix for our radio livestream
so we need to switch from Live to Offline playlist.
now we need to : - stop - change playlist - start
but if we can program F1 to change the playlist to live and F2 to off-line it will be easyer for our jocks to do this.
thx !
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
can you explain a little more ? if you have one source that is on live and one playlist, you only need to add one shortcut, so when you press "F1" for example cut/fade to input1(live) and "F2" to cut/fade to the input2(playlist) uses automatically play on transition.
@ Toongielen
This should be possible with the Shortcut Functions:
StopPlayList SelectPlayList StartPlayList
Applied in that order to the same "Cloned" key (i.e. F1 for Playlist 1 and F2 for Playlist 2) Or to each their own key and then added to F1 and F2 respectfully in the Advanced tab. (I assume you have two distinct "Playlists" that you need to switch between)
Feature Requests
