NDI
adobe after effects control via NDI
Today I try use after effects for titles in vmix via NDI. I can't understand, how sync starting playing composition in AF and play NDI overlay in Vmix at the same time.
Any variants?
Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
I'd advise using the NEWBLUEFX titling that is in vmix 20. its a much simpler solution.
Is NewBlueFX included in vMix 20? It was my understanding that they added NDI Command support in vMix 20 which means you can now control NewBlueFX thru the NDI connection.
After Effects doesn't have any control from NDI, you have to manually control it.
Kane Peterson NewTek
NDI
