Feature Requests
Feature request: Option not to have replay input go to Preview
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Hi again.
Whenever you play out an event from replay, after the event is complete and transition out, Replay goes to preview.
Would it be possible to add the option if having the replay play out events behave like CutDirect, so that you don't end up with the Replay in Preview ? This could be implemented by a simple checkbox in Replay settings.
Best, Jon
+1 It is very unlikely that we will go back to a replay after it is finished, but do need to have the next few shots set and ready.
Joined: 8/13/2017(UTC) Posts: 17 Location: Minnesota, United States
Thanks: 13 times Was thanked: 3 time(s) in 2 post(s)
I would like that as well.
Joined: 12/8/2022(UTC) Posts: 165  Thanks: 50 times Was thanked: 3 time(s) in 3 post(s)
+1!
...if this is not solved already. If so I´d appreciate a pointer.
But I cannot find an option/function in vMix 29 for the replay event to not go into preview after using the play last event button. I would like whatever was in preview to still be there after the running the replay.
Feature Requests
