Feature Requests
Video Delay in milliseconds for Captured Inputs
Joined: 10/9/2012(UTC) Posts: 40   Location: lebanon Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Hi Martin, We are testing VMIX for some up coming projects and we stumbled across a simple draw back. We have multiple sources going in to Vmix, eight Live sources some are looping through some devices which results in 1 or two frames delay than the other sources. Is it possible to have a small buffer in milliseconds in the capturing inputs that way if needed you can fiddle with it so all sources match. Your feedback is highly appreciated, since it will determine if a hardware video delayer should be present or not. Thanks,
Ali
Joined: 11/14/2012(UTC) Posts: 395  Location: Finland Thanks: 250 times Was thanked: 36 time(s) in 34 post(s)
ali wrote: We are testing VMIX for some up coming projects and we stumbled across a simple draw back. We have multiple sources going in to Vmix, eight Live sources some are looping through some devices which results in 1 or two frames delay than the other sources. Is it possible to have a small buffer in milliseconds in the capturing inputs that way if needed you can fiddle with it so all sources match. Your feedback is highly appreciated, since it will determine if a hardware video delayer should be present or not. Thanks, Ali
Would like to have this feature too, to easily sync HDV source with other sources that have shorter delay. Kind regards, J. Tervo
Video mixed with vMix (studio portions). Turn subtitles / CC on:
Feature Requests
