azam
#1 Posted : Thursday, August 3, 2017 12:55:15 AM(UTC)
azam
Hello Everyone,
I am new here. I want to know more about Ruby build.
Please what is the PART NUMBER of the DDR4 RAM?
In building this RUBY system can I add a separate HDD for the operating system then dedicate the 1TB for internal storage if yes will the PSU
still be 600W ATX?
Will this GIGABYTE GA-Z270N-Gaming 5 Lga1151 Intel Z270 Rgb Fusion Hdmi Dp Usb3.1 Type-C Mini-Itx Ddr4 Gaming Motherboard P/N GA-Z270N-Gaming 5 be ok? if not specify.
Can someone help produce a video on how to build RUBY system step by step?
I will be grateful for your help.
[/b]
SportsNetUSA.net
#2 Posted : Thursday, August 3, 2017 3:03:16 AM(UTC)
SportsNetUSA.net
vMix Reference Systems states using a Gigabyte Z270MX-Gaming 5 Intel Z270. Not much of a price difference from the GA-Z270N-Gaming, so you may want to go with what's on the Reference List.
http://www.vmix.com/products/vm...erence-systems.aspx#ruby
Many different brands of RAM modules would work, get something of quality that works with GIGABYTE boards. Download the GIGABYTE Memory Support List
http://www.gigabyte.us/Motherbo...ing-5-rev-10#support-doc
still be 600W ATX?
Yes, it's a good idea to have two drives. A quality 600W power supply should be enough.
There are many videos on YouTube demonstrating how to build a PC.
https://www.youtube.com/results?search_query=build+a+pc
One of the things probably not covered specifically would be installing the video capture card.
If you've never built a computer before, you may want to get someone to build it for you. Or at least get someone who's done several builds to assist you.
Don't forget the specified graphics card!
azam
#3 Posted : Thursday, August 17, 2017 7:39:27 PM(UTC)
azam
HELLO,
I AM INDEED GRATEFUL FOR YOUR QUICK RESPONSE AND THE ANSWER YOU PROVIDED.
I AM OVERJOYED. THANK YOU ONCE AGAIN FOR CLEARING MY DOUBTS AND FEARS.
