Anyway to control another instance without scripts?
Trying to setup this workflow-
Main Vmix computer - ouputting NDI
Replay computer - inputting Main NDI - looking for a way to trigger a stinger and then transition to the Replay's NDI out to play replay on Main.
I can do this via web controller but I really would like to be able to do this via a trigger so that when the replay plays, it automatically transition the main computer to that replay.
Any thoughts?
I was going to setup an AHK shortcut for it -- wonder if that is a possibility?
Joined: 9/13/2016(UTC) Posts: 112   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Yes. It may make sense to create an interface that will make it possible without the use of scripts (and simply connect to another computer with VMIX) in a simplified way. It will be very convenient for those who have to use several systems and there is no way to plant an individual to control the second system. By principle, the leader and the slave.
It's not very convenient if you need to quickly configure the system - write scripts, check their work ... it would be much faster to find the desired function on the second VMIX and use it in work.
