Damaged record: record + replay :(
Joined: 7/31/2017(UTC) Posts: 12   Location: M4R3C Thanks: 3 times Was thanked: 4 time(s) in 4 post(s)
Hello, I wanted to have a question Did not anyone have this problem? I've been doing 2 hours of transmission on Vmix. After finishing I ended the vmix stream properly and everything around. He waited and closed. Turning off the PC after about 10 minutes I turned on the computer because I realized that I did not send a record. I turned on the pc and found out a really bad thing: (((( I know vMix makes a record of InstantReplay after 20 minutes Please do not know if you can get the record somehow? . I guess I guess not .. :( Has this happened to you when using version 19.0.0.54? I would quite need the record .. :( I would have understood if it had been bad since the first set of uploading ... But this? Attaching photos for preview streaming was 29072017 09:58 to 12:01 which I see written in the header of the file as well. Vmix did not write a single error during this stream. That he could not write a record or not. Yesterday I broadcast it without a single problem. When I open my project in Vmix, I do not even match InstantReplay. And when I want to map it to this folder I will write this error .. :( I am sorry for my english....:(( Have a nice day M4R3C Intel Xeon X5650 2,67GHz , 266GHz (2processors) 8GB RAM NVIDIA GeForce GTX 1050Ti recording HDD SSD Kingston SV300S37A240G win: 7 prof .photo https://photos.app.goo.gl/9QVHprqQ7ZrxvnLE2https://photos.app.goo.gl/5fEXEJrJhfbhqsoC3https://photos.app.goo.gl/M7pxrDH51cdsSn513
