Joined: 7/4/2017(UTC) Posts: 4 Location: Buenos Aires
I am testing vmix for use it in a four independent screen setup. So I'm using the maximum simultaneous Vmix outputs (FullScreen1, Fullscreen2, External1 & External2) I found the Launchpad device is a ideal addon to use it with the VMix Activators function. But I can't find the right options inside the Activators pane to control the Lights the way I need . Do am I missing something ? Bellow is an illustration of what i need. Basically I use the first four rows of buttons as a Input Switcher for each of the four screens Outputs. I need that only one button keep lighted on each row, indicating which Input is active on that row http://imgur.com/a/Z5y1v mariano_mena attached the following image(s):  launchpad.jpg (327kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
