NHT
#1 Posted : Saturday, July 29, 2017 3:35:35 PM(UTC)
NHT
Hi guys, I'm looking to do a project where I will have 2 or possibly more vMix machines feeding a master machine from different locations streaming over the web.
What's the most efficient way to pull each machine into the master machine and could I see a data bottle neck even with say a 100mbps connection?
Thanks for your thoughts.
#2 Posted : Saturday, July 29, 2017 4:27:14 PM(UTC)
@ NHT
Without knowing too much about your specific purpose and/or actual geographic parameters, I would probably suggest vMixCall if you must use the Internet.
NDI would be possible (and has been done across several Kms) on a LAN.
Failing that, I would think direct SDI connections if you are within 300 ft of each other (or possibly longer with SDI/Cat5 converter systems).
There are likely a lot of different options possible, you'll just have to describe your situation in a little more detail.
NHT
#3 Posted : Saturday, July 29, 2017 5:12:17 PM(UTC)
NHT
Thanks for the reply Ice.
The machines will be hundred of miles apart, imagine each remote like a small sat truck feeding into a studio.
vMix call is an option I considered, also setting up a dedicated Facebook or Youtube live stream from each site.
I just wondered what other people have done in the past and if certain feed types were more stable or efficient.
Thanks again.
#4 Posted : Saturday, July 29, 2017 8:52:53 PM(UTC)
@ NHT
Check out richardgatarki's very creative use of vMixCall with cell phones in the streets and a couple instances of vMix in the Studio to do these two Live Shows:
https://forums.vmix.com/...aspx?g=posts&t=10960
Another very clever use of cameras using Teradek Bonds to stream from the golf course back to a Studio hundreds of miles away (Arkansas to Wisconsin) by jvphobic where he used vMix to mix and produce the live stream:
https://forums.vmix.com/...aspx?g=posts&t=10723
Where there's a will, you'll find a way!
Some great ideas for you explore there.
