Ash
#1 Posted : Friday, July 28, 2017 2:57:54 AM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Hi
I have been asked to share Ozy Rules Scoreboard, so here it is.
You will need the Pro/4k Version of vMix
Another alternative if you don't have Pro is to use the excellent UTC application. All that's lacking there is a spinner to change the +3 to +6 or any other values you want. I am sure Elgarf can do this if asked.
There is also a ZIP file attached here as a demo to build on. The graphics are from a game streamed here in Tasmania a month or so ago. Feel free to change it.
Could not find a method to recognise a key input from vMix at the time and don't suppose there is a solution now, but maybe vMix 20 will improve scripting, if there is a method then it's possible to cut the code down a bit.
Scripts
Code:
'---Footy_Home_Goal-----
dim fa = input.find("Footy_Full.xaml")
dim fs = input.find("Footy_Pts_Only.xaml")
dim fq = input.find("Footy_Quarter.xaml")
dim HG = cint(fa.text("HG") + 1 )
fa.text("HG") = HG
fq.text("HQG") = HG
dim HGP = cint(fa.text("HG") * 6)
dim HP = cint(fa.text("HP"))
dim HQP = HP
fa.text("HTP") = HGP + HP
fs.text("HP") = HGP + HP
fq.text("HTP") = HGP + HP
'fq.text("HQP") = HGP + HP
'----Footy_Away_Goal-----
dim AG = cint(fa.text("AG") + 1)
fa.text("AG") = AG
fq.text("AQG") = AG
dim AGP = cint(fa.text("AG") * 6)
dim AP = cint(fa.text("AP"))
fa.text("ATP") = AGP + AP
fs.text("AP") = AGP + AP
fq.text("AQT") = AGP + AP
'fq.text("AQP") = AGP + AP
'-----Footy_Home_Point
dim HP = cint(fa.text("HP") + 1)
fa.text("HP") = HP
fq.text("HQP") = HP
dim HGtoP = cint(fa.text("HG") * 6)
fa.text("HTP") = HGtoP + HP
fs.text("HP") = HGtoP + HP
fq.text("HTP") = HGtoP + HP
'----Footy_Away_Point
dim AP = cint(fa.text("AP") + 1)
fa.text("AP") = AP
fq.text("AQP") = AP
dim AGtoP = cint(fa.text("AG") * 6)
fa.text("ATP") = AGtoP + AP
fs.text("AP") = AGtoP + AP
fq.text("AQT") = AGtoP + AP
'---- Home_Reset
fa.text("HG") = 0
fq.text("HQG") = 0
fa.text("HP") = 0
fa.text("HTP") = 0
fs.text("HP") = 0
fq.text("HQP") = 0
fq.text("HTP") = 0
'---Away_Reset
fa.text("AG") = 0
fq.text("AQG") = 0
fa.text("AP") = 0
fa.text("ATP") = 0
fs.text("AP") = 0
fq.text("AQP") = 0
fq.text("AQT") = 0
'----- Footy_Clocks_Start
API.Function("StartCountDown","Footy_Full.xaml")
API.Function("StartCountDown","Footy_Pts_Only.xaml")
API.Function("StartCountDown","Footy_Quarter.xaml")
'----- Footy_Clocks_Pause
API.Function("SuspendCountDown","Footy_Full.xaml")
API.Function("SuspendCountDown","Footy_Pts_Only.xaml")
API.Function("SuspendCountDown","Footy_Quarter.xaml")
'----- Footy_Clocks_Zero
API.Function("ChangeCountDown","Footy_Full.xaml","00:00")
API.Function("ChangeCountDown","Footy_Pts_Only.xaml","00:00")
API.Function("ChangeCountDown","Footy_Quarter.xaml","00:00")
File Attachment(s):
OzFooty.zip (138kb) downloaded 69 time(s).
thanks 2 users thanked Ash for this useful post.
gez737 on 7/28/2017(UTC), Gooey on 10/8/2017(UTC)
Gooey
#2 Posted : Sunday, October 8, 2017 8:51:18 AM(UTC)
Gooey
Great work with the demo Ash.
I've been trying to do a version, where I blank out where you have TSL and NEAFL and the logos, so there's just a grey background.
I'm hoping that there's a way via vMix to add to fields over the top where I can change the home team and away team (like the other scoreboard graphics).
Any idea on how to do that?
Ash
#3 Posted : Thursday, November 23, 2017 1:42:00 PM(UTC)
Ash
Hi Gooey
The background is just a png file, so import into graphic editor and blank out the area.
Cheers
[Edit]
Think I mis-read your post Goeey
Please find attached updated Quarter Graphic with the left hand home pic and away pics added as xaml images.
As long as you use images of similar size (142x78) then there should not be a problem to replace them with wahtever team is playing.
Ash
File Attachment(s):
Footy_Quarter_V2_XAML.zip (50kb) downloaded 41 time(s).
thanks 1 user thanked Ash for this useful post.
Gooey on 7/25/2018(UTC)
