roverradio
#1 Posted : Wednesday, July 26, 2017 5:52:18 PM(UTC)
roverradio
We're using about 4% CPU during very complex productions. Unfortunately there are only 2 external outputs.
It would add great flexibility to have more than 2 external outputs (to route a vMix call to a specific piece of equipment for instance). We're currently using 2 externals (1 for Program, 1 for a 6-up return feed to another studio). Another 2 external outputs would be VERY handy, and seems to be more than doable on a decent system.
Thanks!
#2 Posted : Wednesday, July 26, 2017 6:12:37 PM(UTC)
@ roverradio
Then you will likely be very happy with vMix 20 or vMix 2X as it is to be known!
Many of us are anticipating the beta release sometime in the next few months. Check out the June vMix Funtime Live Show from Atlanta and Tom Sinclair's Streaming Idiots Show on June 14th for some of the details.
roverradio
#3 Posted : Wednesday, July 26, 2017 10:12:20 PM(UTC)
roverradio
That will be absolutely perfect! 4 will probably suffice for us just fine. Thanks
mashynewie2
#4 Posted : Thursday, July 27, 2017 11:22:36 PM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
I used 4 just recently.
- 2 outputs on Defklink
- 2 full screen outputs on the graphics card.
