rinaldo
#1 Posted : Sunday, July 23, 2017 6:02:57 AM(UTC)
rinaldo
I'm looking for a portable monitor solution to fit in my vMix rack 19'' system. I've seen AOC E1759FWU ---> https://www.amazon.it/AO...ywords=monitor+17+16%3A9
Uses USB 3.0 for power and for signal with 1600x900 resolutions. Can be ok?
#2 Posted : Sunday, July 23, 2017 6:09:59 AM(UTC)
Hi
it seems it should work.
However
- Why use USB3?
- I'd rather look for a 1920x1080 monitor for more space and mostly better monitoring for focus
rinaldo
#3 Posted : Sunday, July 23, 2017 8:49:41 AM(UTC)
rinaldo
DWAM wrote:
Hi
However
- Why use USB3?
USB 3 because is the only monitor I can find on the market that fits on this rack slider ---> https://www.thomann.de/i...413_19_monitorauszug.htm
Bigger will be better for shure but I need portable operation. If you have some suggestion on other solutions let me know TNX
#4 Posted : Sunday, July 23, 2017 9:23:49 AM(UTC)
It's more expensive, I know, but Blackmagic and other manufacturers do rackable monitors
17" with FullHD resolution
Did you check this?
https://www.spartonre.co..._Ku-P9nNUCFUQq0wodBHkJZw
https://www.blackmagicde...om/fr/products/smartview
http://www.lcdracks.com/
