michaelrb
#1 Posted : Friday, July 21, 2017 10:18:44 AM(UTC)
michaelrb
Yesterday, I was able to stream to Periscope and Facebook(using a custom rtmp). Today I can't. Stream button turns yellow, then I get an error report. Here is a screenshot. I'm a newby, let me know what other info you might need to help with this. Thanks...Michael
michaelrb attached the following image(s):
#2 Posted: : Friday, July 21, 2017 11:22:32 AM(UTC)
Hi
this very same error message has been reported many times. Did you search the forum before posting?
It seems you're sending too much data to Periscope (or Facebook). Check carefully their requirements for streaming especially bitrates and conform your parameters so that they match.
Guillaume
michaelrb
#3 Posted : Friday, July 21, 2017 2:33:51 PM(UTC)
michaelrb
Thanks Guillaume. Yes I did try to search this topic but no responses seemed to mimic my problems. Today I went into vmix and deleted my streaming credentials, then re-established them. I got a "Periscope API Error" which I ignored. I was then able to stream to both facebook and periscope for over 1.5 hours with no problem. I guess this could be a work around. Will also get streaming requirements from both Facebook and Periscope to insure I can stream properly. Any other suggestions?......
