tzichterman
#1 Posted : Tuesday, July 18, 2017 2:34:41 PM(UTC)
tzichterman
This would make my life so much simpler as I use the web controller for every broadcast but have so many buttons it is difficult to tell them apart at a glance.
Thanks!
#2 Posted : Tuesday, July 18, 2017 2:50:56 PM(UTC)
@ tzichterman
Which Controller are you using?
Different controllers have different options available but AFAIK, not all MIDI devices are supported in vMix with respect to all of their respective colour options...
Edit: My bad, thinking you were referring to a midi controller and not merely the web interface controller... Even so, which 'page' are you using? The "Shortcuts" page is what I prefer as it has 'labelled' buttons and is more configurable than the overview "Inputs" page and AFAIK, none of those web controller buttons cannot be altered, but I see the benefit of having some sort of "Category" colour coordination (maybe Category Colour outline of the button, so + 1 in that respect).
Sorry for misunderstanding your request.
#3 Posted : Tuesday, July 18, 2017 7:05:11 PM(UTC)
Hi
You could try vMix UTC. It allows to make your own user interface for vMix on a remote computer and obviously you can arrange the buttons the way you like, create areas to separate cam inputs from titles and so on...
It can work with vMix shortcuts directly but it is usually better to create your shorcuts to vMix in UTC by using specific buttons.
You can find UTC here: https://forums.vmix.com/....aspx?g=posts&t=6468
And more info here: https://forums.vmix.com/....aspx?g=posts&t=9393
Guillaume
