Tom C
#1 Posted : Sunday, July 9, 2017 3:58:19 PM(UTC)
Tom C
I am recording capture rom 2 webcams. I can't find the recorded video. I know where it's set up to go, but they aren't there. Just previous videos.
I haven't used this software fro 6 months, I am supposed to do something after stopping the recording?
#2 Posted : Sunday, July 9, 2017 4:21:41 PM(UTC)
@ Tom C
Are you sure it recorded?
Usually for me, vMix requires me to set-up (confirm) the recording (location/title etc. prior to being able to record).
If I don't know where the most recent recorded file went, I'll often attempt a new recording as vMix will (should) default to the last location designated, and take note of where that is on my computer and go there to retrieve the most recent recording.
Hope that helps some.
Digitalson
#3 Posted : Friday, July 14, 2017 1:49:29 AM(UTC)
Digitalson
Groups:
What I do if running a multi cam show is record all cameras in a ssd video deck locked to the daw via timecode recording the multi audio and just record the master with a cue mix from the daw for reference,then in post I can just multi cam with a mix from daw with same timecode so everything lines up perfectly,,in Adobe premiere 2017,cause I could not get vmix to multi record more than 3 cameras and a master at same time ,and that's with 4 ssd"s in a raid 0 configuration,,,,the speed is around 2 gb per sec ,and no go
