getsmarttech@xtra.co.nz
#1 Posted : Tuesday, July 4, 2017 6:35:23 AM(UTC)
We'd like to insert part or all file name as a subtitle?
Even better if we could find something That could use the metadata.
Any Ideas?
#2 Posted : Tuesday, July 4, 2017 6:48:35 AM(UTC)
Hi
a tool like mediainfo makes it possible to get metadata exported to XML, CSV, TXT, etc... Then you can use datasource to get the filename or whatever. This requires a little scripting knowledge but not much.
https://mediaarea.net/
Alternatively, Jens, an advanced user, did a video showing how to use vMix API in order to retrieve video titles in realtime
There are other solutions, search the forum
Guillaume
