Hi to all,
what i have to set, to use a vmix directly with the teradek cube? Only my own wireless network? i test cince a few ours, but i don`t get it.
Thank you!
Sven
I tested my old cube 250 (TX) with vMix 10 preview as an input in vMix during the last days, wired as well as wireless and it finally worked. I was a long way to get it working... but mostly because of issues outside vMix, like wireless channels, cube firmware, camera output...
Do you want to stream the vMix output with your cube or do you want to receive your stream from the cube as an input source for vMix?
I always tried first to receive the stream on VLC, if that worked, started trying vMix as receiver. And it was a lot easier to start testing with the cube using a cable and not on wifi (with turned off, not just unused!).
Hi Markus,
I want to receive the cube Stream into vmix, without a additional vlc Player. I don't know how to start! Only cube and vmix and my network.
Lg
Sven
Do setup the cube as described in cube's manual. Do connect a video source to the cube and start streaming. Go to cube's webinterface and copy the linke to your stream (sth. like rtsp://192.168.1.2/stream1 for example). Start vMix, add an input, select Tab "stream" (vMix 10) past the link and use the stream type "RTSP over UPD" for example. Hit "Ok" button and enjoy your stream as an input-soruce on vMix. ;)
