cruiseweekTV
#1 Posted : Wednesday, June 28, 2017 7:03:19 AM(UTC)
cruiseweekTV
Was thanked: 3 time(s) in 1 post(s)
Situation:
I have 2 vmix calls running, one is a cohost, one is a guest. I want to co host to listen to the audio of bus A which also contains the producer mic so he can give directions and audio cues, but guest just needs the normal master out audio as they will get confused hearing the producter.
Right now you can only change it for all vmix calls, not per call
#2 Posted : Wednesday, June 28, 2017 7:44:11 AM(UTC)
AFAIK you can choose which audio to return to each guest
cruiseweekTV
#3 Posted : Thursday, June 29, 2017 2:49:57 AM(UTC)
cruiseweekTV
I tried his and it changed it for all guest :(
richardgatarski
#4 Posted : Thursday, June 29, 2017 11:56:09 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
Each Video Call Input can when added be set to use Master, Bus A, or Bus B as return audio source. I have sucessfully many times have had callers listen to different audio sources.
AFAIK you cannot change the return audio (or video) source for a Video Call Input. Think I asked for that a while ago, but can't find that post.
(If you are brave you can edit the return audio source manually in the preset file).
So please cruiseweekTV, explain what you tried. Any additional info might help us assist you.
cruiseweekTV
#5 Posted : Thursday, June 29, 2017 11:38:32 PM(UTC)
cruiseweekTV
1: created guest 1 vmix call, set the audio to master
2: created co host vmix call, set audio to bus a
3: go check guest one's settings and see audio is now also showing bus a
