Is there a way to record the last 24 hrs of video to my HDD? We would like to use it as survailance recording, but by law we can only record 24hrs of video - then we have to delete what is over 24 hrs. I was thinking of continuous 24hr recording where we can check the last 24 hrs, but don't need to delete anything manualy.
If vmix does not offer this, is there any other program that would do the job?
Thank you, regards Caitanya
If you are using the video only for survailance recording, you do not need to use vMix unless you want to do so...there are simple capture software out there, and if you want to record more than 24 hours, get a much larger HDD...you can now get 3tb and larger.
