CristianGib
#1 Posted : Thursday, June 15, 2017 12:36:44 AM(UTC)
CristianGib
I would love to see in our beloved software the option to run widescreen resolutions. In my particular case, I would like to feed ultrawide resolution to edge blended projectors and stream it at the same time. In saying that would be even better if is possible to choose different aspect ratios on your main output and streaming output.Lets say 21:9 main output and 16:9 streaming (Re-scaled of course)
Thanks for this great software
thanks 1 user thanked CristianGib for this useful post.
PFBM on 1/31/2019(UTC)
insanmks
#2 Posted : Tuesday, January 29, 2019 12:04:03 AM(UTC)
insanmks
Saudi Arabia
I have the same requirement
right now im puting output location at display 2, and giving 2 outputs from PC to LED screen(18x3) half display on each output. this way im getting a 4k Output as one, but my problem is aspect ratio on preview/program/input displays..
thanks 1 user thanked insanmks for this useful post.
markleman
#3 Posted : Thursday, January 31, 2019 9:45:47 PM(UTC)
markleman
I was looking for a similar thing i.e. stream and output a different aspect ratio and raised it as question here https://forums.vmix.com/...utputs--one-16-9-one-4-3
Recently I solved my problem by using the 'external output' feature of vmix and external program to crop and scale the output to my preferred dimensions.
See my original thread for the solution using ffplay or mpv. I expect you could use this method to take parts of the output to different projectors.
I would also like to see the option within vmix to specify the aspect ratio of the outputs to be different from the main project.
Mark Leman
