Welcome Guest! To enable all features please Registers on the forum or Registers.
richardgatarski
#1 Posted : Monday, June 12, 2017 11:09:42 AM(UTC)
richardgatarski
When setting up a Facebook stream the settings are invisible after clicking "Close". And AFAIK it is impossible to see on the Facebook stream Settings page if that stream is setup or not.
EDIT: I would like to see this info on the Streaming Settings page when Facebook is selected as Destination, without having to click through to the Facebook settings page.
I suggest that the "Facebook Settings" button is changed to two states, with additional info (truncated to fit in one line each):
1. Set up the Facebook stream
2. Change Facebook stream settings for:
[title]: [description...]
[location]: [privacy]
cacooley
#2 Posted : Tuesday, June 27, 2017 6:04:23 AM(UTC)
cacooley
You can see the settings for FB by going back into it, They will be grayed out since the stream key is associated to those attributes. It may not be possible to change those attributes once the stream key is created. You just have to click end stream, make your changes and create new stream.
richardgatarski
#3 Posted : Thursday, June 29, 2017 11:58:40 AM(UTC)
richardgatarski
cacooley, thanks I know that. I will edit my initial post as to clarify what I am after.
