skatejack
#1 Posted : Saturday, June 10, 2017 3:10:17 PM(UTC)
skatejack
I am using vMix v17, and when i try to connect to an RTSP stream (from IP Encoder) i get the error "no session".
The same stream I open it from VLC Player without problems.
an I get more details about this error? What could be the problem?
Thanks!
#2 Posted : Saturday, June 10, 2017 7:31:04 PM(UTC)
Hi
it could be a codec issue, especially audio.
However you should update to v19 which now uses VLC to provide an alternate input type for streams.
Guillaume
