ortana
#1 Posted : Friday, June 9, 2017 4:03:58 AM(UTC)
ortana
Really simple and I am sure dumb question, but I am not able to find in the documentation an API call that allows you to find out the status of vMix. I am just looking to poll it to to see if recordings / external are enabled, etc.
All and any help much appreciated!
pm
#2 Posted : Friday, June 9, 2017 4:14:14 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
http://www.vmix.com/help19/DeveloperAPI.html -> Topic "Information"
"If all parameters are left blank the API will return state information in XML format.
The following is an example of the XML output:..."
http://127.0.0.1:8088/API
Patrick
