Hello, I am currently using the VLC input to connect via RTMP to a cheap IP camera. http://www.ebay.com.au/i...47409:g:KJ8AAOSwV-RXFFRrIt works VERY WELL however sometimes locks up (paused picture) in my trials and I have to right-click and reset the input to get it to work again. Can there be a function where vMix detects the paused input and resets the connection? Or should I provide logs to Martin so he can find out why it locks up? I would like to put a heap of cameras on vMix and stream them 24/7 so it needs to be unattended. ****OR***** You could make a tick box where it only makes an RTMP connection when the camera is in preview or program. This would allow an unlimited amount of cameras and they only use bandwidth when they are selected. Thanks
Thanks: 24 times Was thanked: 6 time(s) in 5 post(s)
I have three cameras connected but only the one connected via WiFi seems to be a problem - the other two are on Cat5e
