sunkast
#1 Posted : Friday, June 2, 2017 5:36:14 PM(UTC)
sunkast
I would like to request some sort of call connection indicator on vMix Call input modules. While the call manager is fantastic, often times I am running vMix from a single monitor, making it difficult to tell whether a call has connected or disconnected. If there was some sort of red/green light to indicate the whether the call is connected or disconnected would be very helpful without having to switch to the call manager while producing using vMix on a single monitor.
#2 Posted : Friday, June 2, 2017 7:59:19 PM(UTC)
@ sunkast
Excellent suggestion, very similar to this one by sinc747:
https://forums.vmix.com/...aspx?g=posts&t=10861
Always good to add your support or input on previous requests...
