alternativa939
#1 Posted : Wednesday, May 31, 2017 6:19:24 PM(UTC)
alternativa939
You have been a member since:: 5/31/2017(UTC)
I use VMIX to make visual radio and it would be very interesting to be able to improve the playlist.
1 / videos already played are removed from the list
2- drag and drop directly position the videos in the desired position.
3. loop option in each file
4. When playing an audio file or not containing video, you can define a background image.
5. continue reproducing the list for more that is not live (this allows you to exchange with cameras without cutting the audio) "SOLVED"
6. be able to configure a view where only the playlist is viewed and output without the preview.
7. Now play files to share on social networks
8. Tigger on title change for NOWPLAYING Overlay in out
9. Single countdown per iche file
