jstevens
#1 Posted : Saturday, June 29, 2013 11:39:53 AM(UTC)
jstevens
Really love vMix. We are looking to use it for Livestream in our church setting. I tested the system with two USB webcam and that was easy enough. Next is to try it with our two Robotic SD cameras.
Would the Blackmagic Decklink Studio enable use to connect both cameras and use with vMix or would we need two capture cards or some other solution?
Thanks for your patience.
John
