Mojomania
#1 Posted : Tuesday, May 30, 2017 1:42:07 PM(UTC)
Mojomania
A quick question.
If you are using the ATEM Studio HD switcher for your inputs and you output from and into VMIX, does that technically mean you are only taking up one camera input in Vmix and switching from the ATEM instead?
kjones9999
#2 Posted : Tuesday, May 30, 2017 2:00:14 PM(UTC)
kjones9999
That's correct....
#3 Posted : Tuesday, May 30, 2017 2:06:06 PM(UTC)
Views messages in topic : 2,721
This is correct for previous ATEM Television Studio
This new model has an AUX out which can be used for a second input in vMix.
There are also 4 SDI outs which seem to be routable but I can't find no information to be absolutely sure whether these can output up to 4 independent cameras inputs. If you find the answer, please keep up posted.
Guillaume
elvis55
#4 Posted : Tuesday, May 30, 2017 2:23:17 PM(UTC)
elvis55
Switzerland
ATEM Television Studio features built in talkback that takes advantage of rarely used SDI channels 15 and 16 to send talkback audio to and from the camera. There's also headset connections on the front panel for talking to and listening from cameras that support SDI talkback. The talkback from the camera is embedded in the SDI video feed from the camera to the switcher. If you connect the talkback SDI outputs of the switcher back to the camera, then the director’s talkback audio is sent to the cameras along with tally and camera control. The 4 SDI outputs feature talkback to cameras with mix minus. This lets you send program audio back to an interviewee so they hear everything except themselves, and won’t be distracted by hearing a delayed audio echo.
https://www.blackmagicde...diohd/techspecs#W-APS-08
Gruss
#5 Posted : Tuesday, May 30, 2017 2:28:54 PM(UTC)
Yes I know about talkbalk feature and also remote control for color/iris of the camera.
What I would like to know is whether these SDI outs can be used for any camera inputs (like a router) or only with PGM signal.
Thremir
#6 Posted : Tuesday, May 30, 2017 5:44:11 PM(UTC)
Thremir
They are PGM only
thanks 1 user thanked Thremir for this useful post.
DWAM on 5/30/2017(UTC)
#7 Posted : Tuesday, May 30, 2017 5:57:20 PM(UTC)
Thanks Thremir... Too bad... ;o(
