Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
Hi i just got this Jl cooper controller, its really neat, want to get it working.https://jlcooper.com/_php/product.php?prod=mcs3rs422 and i bought this also. https://www.startech.com...l-Cable-Adapter~ICUSB422 i installed and still cant get it to work, i think it is a com port setting. I did open up the jl cooper device and change some stuff like it says in the manual. the adapter is showing in device manager and all software loads. Thank You
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
It will never work, not without a special vMix driver. And the is an old unit so I don't see it happening. The current controllers are all USB. They are MIDI type controllers. This is basically a Sony VTR controller.
There are a lot of old Sony RS422 Controllers out there, but I don't see a lot of people asking for it.
Steve
