aircooled76@gmail.com
#1 Posted : Monday, May 15, 2017 4:04:56 AM(UTC)
Hi Guys,
Firstly I love the replay function and vMix. You guys are incredible.
A few little tweaks I would love:
I never use the "live" mode in my replay as I want to choose my in and out points myself. Every time I press record to start recording the replays the default behavior is for Live to be selected. If I forget to change this all my in and outs are based on live not play head and are useless. I request you add an option to make the replay machine default to "non live" mode on start record. A simple checkbox would be great in the replay settings.
Two when I choose to play events and allow the switcher to RTD / stinger to the replay, when it gets to the end of the event it jumps to the start. It would be better to hold on the last frame so we can switch off the event. Or even better EVS systems just play past the out point for a max of 5 seconds to allow the transition out...
thanks guys
Mike
