Basel
#1 Posted : Sunday, April 30, 2017 1:06:50 PM(UTC)
Basel
I hope that there will be a section where I can specify the amount of delay taken before triggering a key in addition to a Shortcut, from the advance section of "Add shortcut".
please do it as it will help me a lot :)
thanks
Basel
richardgatarski
#2 Posted : Sunday, April 30, 2017 1:17:39 PM(UTC)
richardgatarski
already possible in scripts (vMix 4K and Pro)
Basel
#3 Posted : Sunday, April 30, 2017 1:23:05 PM(UTC)
Basel
thanks, it would be awesome if you can show me how or give an example :)
#4 Posted : Sunday, April 30, 2017 1:50:05 PM(UTC)
Hi
just use the sleep command as indicated here:
http://www.vmix.com/help19/WebScripting.html
Guillaume
Guest (4)
