Streaming to two custom RTMP servers with the same visuals but different audio
I was asked to cover up a live stream of a lecture with simultaneous translation. My idea is to set up a multi-camera live event on YT with two "cameras" (as they are called there) both with the same visuals but two different audio inputs, so the viewers would have a choice whether they want to listen to original language or the translation. Does vMix provide the possibility to stream to two different RTMP with the same video, but different audio output?
Hi and welcome to the vMix community if you had searched the forum before asking, you'd already have your answer. The same question was asked many times. An example from last week: https://forums.vmix.com/...aspx?g=posts&t=10624Guillaume
Thanks for the answer (and sorry for duplicated thread).
It's mainly for you. There are so many things to learn from this forum by reading previous posts. Also not all guys will see your post or won't bother to give you an answer because they already did many times. Searching the forum is a good habit to take.
Hello, Sorry for my English (Translated from German to English with Translator) I have made a test, possibility of a video livestream on Youtube with 2 channel sound (eg 1 German and 1 English) I do not know if something is asked. For my purposes, it would be the right one. The problem is how can I tell the viewer what he is on senem PC To hear the sound of his speech. When the viewer does that Video starts, the video is mixed 2 languages. With a text in the video description. It must be below the Playback-Speaker-Properties-Level balance Left or right channel. I recorded this in the video from about 2 minutes. Suitable is the zb. For 2 speakers with microphone. My setup and settings: 1 mixer, 2 micro inputs. Microphone 1 - Pan setting to the left. Microphone 2 - Pan setting to the right. These 2 outputs on a Behringer UCA202 USB / Audio Interface. https://www.bhphotovideo...USB_Audio_Interface.htmlThe interface is connected to the PC USB. The remaining setting in VMIX, you can see in the video. I hope I could help one or the other. In the forum I found nothing. Greeting
 1 user thanked elvis55 for this useful post.
