paulmeheux
#1 Posted : Thursday, June 20, 2013 11:21:05 AM(UTC)
paulmeheux
I have just found the web controller and think it is fantastic!
It would be even better if a presenter with an iPad could see the slides and control them from the stage?
I know other systems where you can present from an iPad, but it would be great to still have control and be able to switch between multiple inputs from the control desk.
macjaeger
#2 Posted : Thursday, June 20, 2013 11:28:08 AM(UTC)
macjaeger
By "slides" you mean inputs? So you'd want vMix to send all preview data to your ipad?! I can't imagine that's possible...
paulmeheux
#3 Posted : Thursday, August 8, 2013 7:15:34 AM(UTC)
paulmeheux
Sorry, i just want them to see the output. i.e. their presentation. and be able to control the slides etc from the ipad? I would have full control from production desk and switch between different presentations for different presenters.
Also does anyone know if you can add a Prezi deck into vmix?
Damn2Good4U
#4 Posted : Thursday, August 8, 2013 8:16:00 AM(UTC)
Damn2Good4U
Same here i cant imagine that happening...
The only or simple solution i think is by using a laptop with this type of device "Computer Laptop PC VGA to TV AV, RCA, S-Video Converter Adapter Box" (http://ebay.eu/14y4Udm) which can go into vMix as an input...
I am sure, there will be a converter for iPad that can be use if searched well.
Rottimmy
Guest (4)
