stergi
#1 Posted : Sunday, April 23, 2017 7:59:49 AM(UTC)
stergi
Please allow custom input preview size, under Display Settings.
Best regards
stergi attached the following image(s):
input preview custo size.PNG (21kb) downloaded 5 time(s).
#2 Posted : Sunday, April 23, 2017 1:02:52 PM(UTC)
@ stergi
What size do you want or need?
I suspect the six available choices are there for a reason, customizing them to anything else might not be practical or possible, IDK.
stergi on 4/29/2017(UTC)
stergi
#3 Posted : Saturday, April 29, 2017 2:35:46 PM(UTC)
stergi
IceStream wrote:
@ stergi
Im sure there are for a good reason and vmix guys already gave as 6 custom choises already, no doubt. But this kind of open customisation will allow 18-19 inch monitors, with the majority of them having native resolution 1365 X 768, to fit more input preview windows. if possible, try switching your monitor's resolution from 1920 x 1080 to 1365 X 768 to see what i mean.
Those monitors are very mobile, cheap and lightweight. For professional use and if there is a lot more budget available a sleek solution would probably be a 17" Blackmagic rackmount monitor or something similar.
Another benefit would be that it's the most versatile way if one needs to fit those 18-19" monitors inside a rack which has standard width 48,26mm (19")
I regret that i didn't explained my thoughts to the forum on the first place.
Kind regards
Stergi
Ed Tech
#4 Posted : Saturday, April 29, 2017 9:27:24 PM(UTC)
Ed Tech
+1 I realize it may not be as professional, but when working with younger students, it is a distinct advantage for them to be able to see every input without having to scroll or select and input tab.
thanks 1 user thanked Ed Tech for this useful post.
stergi on 4/30/2017(UTC)
stergi
#5 Posted : Sunday, April 30, 2017 2:28:42 AM(UTC)
stergi
Scrolling is the main disadvantage when working with vmix in 1365x768 monitors and that is the meaning of this request. Although those monitors can display full HD signal, the image is blurry due to upscaling. It has to do with live production flexibility and the ability of Vmix to adapt to existing hardware a user already owns.
Thank you for your comment
