dfgdzg
#1 Posted : Saturday, April 22, 2017 10:40:45 AM(UTC)
dfgdzg
Is there a way I can set up my webpage source to automatically refresh when I display it to the stream?
It plays an animation so I need it to start again every time it's shown.
I know this is possible in other streaming software, and was wondering if I can do this in Vmix and how.
Thanks.
#2 Posted : Saturday, April 22, 2017 10:46:58 AM(UTC)
Hi and welcome to the forum
Check the Browser section in the Shortcut Function Reference of the documention.
http://www.vmix.com/help...utFunctionReference.html
I guess "BrowserReload" is what you're looking for
Guillaume
dfgdzg on 4/22/2017(UTC)
dfgdzg
#3 Posted : Saturday, April 22, 2017 11:04:39 AM(UTC)
dfgdzg
Hey, Thanks this looks like what I need.
I'm struggling to use it though.
What exactly do I add to my URL to make it refresh on transition?
#4 Posted : Saturday, April 22, 2017 12:06:49 PM(UTC)
@ dfgdzg
I would use the "Triggers" feature.
Add the Browser Input
Click cog wheel
Go to Triggers
OnTransitionIn -> BrowserReload -> your browser Input -> 100 ms (or whatever)
ADD
Done
Hope that helps.
dfgdzg
#5 Posted : Saturday, April 22, 2017 12:40:09 PM(UTC)
dfgdzg
Ended up using Restart Input instead but it works perfectly.
Thanks!
palco5
#6 Posted : Monday, February 24, 2020 9:05:31 PM(UTC)
palco5
Originally Posted by: IceStream Go to Quoted Post
@ dfgdzg
Click cog wheel
Go to Triggers
ADD
Done
Hope that helps.
I set everything up but it doesn't work. He does not want to refresh the website. Not work on trigger.
