stigaard
#1 Posted : Saturday, April 15, 2017 5:43:35 AM(UTC)
stigaard
Denmark
Hi vMix staff and all you other guys,
I've discovered a very weird thing with the Instant Replay feature.
Here's my case:
1) I open a preset from previous streams where I have all needed inputs
2) I save the preset as a new file
3) The preset contains a replay input
4) The folder that the replay sessions used were deleted, and I want to use another folder for the replay session for the new
5) vMix prompts to locate where the replay folder is, since it cannot find the original one
6) I select an empty folder where I want my replay session
7) The settings for the replay session is now using the new folder, but there is some problems!
8) The recording format for replay is fixed to 1080p25, and I'm not able to change this. I want to set it to 720p50
Trying to use the "Change"-button in the general settings for the input comes with the message
You can see a demonstration of the problem in this video:
Jens Stigaard
RyanP
#2 Posted : Saturday, October 5, 2024 2:53:28 AM(UTC)
RyanP
Delete replay inputs and add new replay inputs. That should do the trick.
