Datasources format title editor issue
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Stumbled on something very annoying when editing titles and specifying a format: one can not edit them, as they revert to the standard {0} if one attempts this and not the one previously specified like "Name: {0}" as per user guide.
This is especially a problem if one wants to tweak a lot of format settings with lots of fields containing a link for example like " c:\..\{0}.png" (using rows to columns in a ranking list for example)
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Thanks for the report, we'll get this fixed very soon.
Just to confirm, you can edit the format field and it will work as expected, but the bug is when going back in to the settings again it will show "{0}" even though something else is actually set behind the scenes.
Martin vMix
THANK YOU !
Yes it works as expected,even when loading it from saved presets, the moment one goes into editing the field it is lost even if one cancels.
Again thank you for the quick response
