wkroeplin
#1 Posted : Friday, June 14, 2013 10:40:48 AM(UTC)
wkroeplin
I am trying to set up my macbook to stream Powerpoint to my PC where I have VMix running. It is pixelized and delayed. In another post I explain: http://forums.vmix.com.a....aspx?g=posts&t=1028
What I am wondering: Is there anyone else using the screen capture feature and how are they doing it?
thanks
Egriswold
#2 Posted : Friday, June 14, 2013 1:16:51 PM(UTC)
Egriswold
Was thanked: 34 time(s) in 33 post(s)
I have done this as recently as two weeks ago over wifi and it worked perfectly. I was even streaming out at 1000kbps
since it was power point I set the frame rate at 15fps and quality to medium.
My first question would be when you select the source and you get the pop up which asks about quality and frame rate what are you selecting ?
