#1 Posted : Saturday, June 1, 2013 1:24:08 PM(UTC)
vMix SD x64 9.1.0.31
Recent observations:
Video delay of output is saved at 50% (or less) speed even though it is set at 100%
Have I missed a setting somewhere?
I usually set up my cameras as a video delay input, but in this case I was using the output as the source which was playing a DVD input of old footage.
The other observation I have is that the saved clip is added immediately next to the Delay input and not at the end of the queue, pushing all subsequent inputs further down the line.
I don't remember this being the behavior, although it has been a couple of months since I have used it and I am not sure if or how this impacts the shortcut key assignments of those other inputs as of yet, just an immediate observation.
rossif76
#2 Posted : Sunday, February 23, 2014 10:41:04 PM(UTC)
rossif76
I'd like to hear an answer to this question, as I'm noticing the same issue. I have to speed it up to about 175% to achieve what I think is 100% speed on an HD input. I am using Bootcamp on a MacBook Pro Retina (Late 2013), and it's the 64-bit version of the most recent vMix release. Thanks for any insights.
- Frank
#3 Posted : Sunday, February 23, 2014 11:19:13 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Hi Frank,
The video capture input frame rate needs to be the same as the frame rate configured in vMix settings.
If the frame rate is different, the video delay will not play back at the same speed.
