Feature Requests
Colour Binding in GT Designer
Joined: 11/2/2018(UTC) Posts: 44  Location: Blantyre Thanks: 6 times
I am requesting a colour binding feature whereby colours for different layers are tied to a single layer's colour property; when that particular layer colour is changed it be reflected to all layers bound to it.
Thanks.
Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: doggy  ? I mean, if we have three solid layers of the colour orange, only one will be set to be visible in vMix. The other two will be getting the colour properties from the visible one. Likewise, if there are several layers of the same colour, we would do the same. This will help us avoid copying colours manually to several layers and will keep the design colours in harmony. Thanks.
Originally Posted by: Fountain Kamanga  I mean, if we have three solid layers of the colour orange, only one will be set to be visible in vMix. The other two will be getting the colour properties from the visible one.
Thanks. First off one can not assign colors to layers in a GT title , you can however to TextBlocks and in the upcomming v25 to shapes'. There are different ways to say synchronize the color changing of a rectangle for example : Have one shortcut change to color for all the wanted elements or using a script that reads the color setting of one shape and applies that color to the others (v25 API.XML will let you read the current color of a shape)
Originally Posted by: doggy  Originally Posted by: Fountain Kamanga  I mean, if we have three solid layers of the colour orange, only one will be set to be visible in vMix. The other two will be getting the colour properties from the visible one.
Thanks. First off one can not assign colors to layers in a GT title , you can however to TextBlocks and in the upcomming v25 to shapes'. There are different ways to say synchronize the color changing of a rectangle for example : Have one shortcut change to color for all the wanted elements or using a script that reads the color setting of one shape and applies that color to the others (v25 API.XML will let you read the current color of a shape) I appreciate for the response, but I am taking advantage of the version 25 feature whereby we can set a shape colour options accessible in vMix. It happens that we have several shapes of the same colour, I wouldn't want all of them show colour options in vMix. I would make one layer's colour options visible and once I change it, all the linked layers should reflect the change. Thanks.  All Layers Showing Colour Options.PNG (104kb) downloaded 8 time(s). Layer Visibility.png (21kb) downloaded 7 time(s). My Request.PNG (54kb) downloaded 7 time(s).
Curious how you would envision the workflow in the designer for example. Yes few lines of script is based on v25 features. Code:dim x as new system.xml.xmldocument
x.loadxml(API.XML())
dim Color as string = (x.SelectSingleNode("//input[@title='sample.gtzip']//color[@name='MasterRectangle.Fill.Color']").Innertext)
API.Function("SetColor",Input:="sample.gtzip",SelectedName:="Rectangle1.Fill.Color",Value:=Color)
API.Function("SetColor",Input:="sample.gtzip",SelectedName:="Rectangle2.Fill.Color",Value:=Color)
Feature Requests
