Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
There seems to be a bug with the fullscreen view when changing display settings within either the AMD Catalyst Control Center or NVidia Control Panel.
I was working on changing some settings on the output screen to enhance the picture quality and clicked apply to change the settings. This somehow changed the fullscreen to go to output 1 instead of output 2. I restarted vMix and had the fullscreen was still on output 1. So I changed the output to screen 3 and it then displayed correctly on output 2. Not liking that I had to have it set on output 3, I fiddled with some settings to finally correct the issue. The trick that seemed to correct the issue was to set display 2 as the primary monitor in windows and then back to 1. This seemed to reset the issue.
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
So that is what you call a bug?.....That is a windows issue....same crap happens with my editing software.....
Bardos59 wrote: So that is what you call a bug?.....That is a windows issue....same crap happens with my editing software..... I'm not a programmer by nature, so I am not sure if that would be a windows bug or a vMix bug. I haven't experience a scenario like that in any other software. What software has that happened to you in?
Rank: Guest
I don't think I explained myself correctly.
I am only running 2 monitors.
In the vMix setting, there are 4 displays show for the Fullscreen option. When the issue happened, the secondary screen correctly identified as monitor 2. So the mismatch came between what windows said was monitor 2 and what vMix said it was outputting to monitor 2.
Sometimes turning off fullscreen and clicking it back on will move it back to the correct window. So with fullscreen enabled, it shows on monitor 1. I then click fullscreen to turn the feed off. I click it again and it then appears on monitor 2. This happens some of the time.
