rhodian
#1 Posted : Tuesday, December 1, 2020 8:12:20 AM(UTC)
rhodian
Is it possible to set the display format (mm:ss etc.) of a countdown timer (XAML Title) using an API function?
Whenever I add the title as an input, the format is set to "hh:mm:ss" and need to set it in "Title Editor | Settings".
rhodian
KVT Berlin
#2 Posted : Sunday, February 13, 2022 6:37:22 AM(UTC)
KVT Berlin
Germany
Hi rhodian,
I'm struggling with the same issue. Did you find a solution?
Thomas
#3 Posted : Sunday, February 13, 2022 6:52:10 AM(UTC)
Originally Posted by: KVT Berlin Go to Quoted Post
Hi rhodian,
Thomas
I one can't find it in the shortcuts one can not set it with an API function.
Alternativly one can make one's own countdown using a script but that's more work than just changing a setting
Dont understand the issue (struggle) of having to set it in "Title Editor | Settings" though
rhodian
#4 Posted : Sunday, February 13, 2022 7:07:41 AM(UTC)
rhodian
Hey Thomas
Hi rhodian,
Thomas
I spoke with support and they indicated that it was the only countdown solution, I got around it by masking out the hours.
Regards
rhodian
#5 Posted : Sunday, February 13, 2022 7:55:54 AM(UTC)
Regards
rhodian
Sorry but i do not understand masking to be the only solution instead of having to set it in "Title Editor | Settings" once during setup.
KVT Berlin
#6 Posted : Sunday, February 13, 2022 7:59:45 PM(UTC)
KVT Berlin
Germany
@rhodian - Thanks
@doggy
I'm using a script to change the text colour of a countdown timer (speaker clock).
Sometimes it is useful to change the display format from "hh:mm:ss" to "hh:mm" automatically during the countdown is running from over to less 1 hour.
It's not handy to do this by editing the "Title Editor" settings.
#7 Posted : Sunday, February 13, 2022 8:14:23 PM(UTC)
@doggy
Ok that makes sense now , thanks
If you are scripting anyway one could create the countdown in the script and format the display of it (and color) accordingly too using vb.net basics using TimeSpan, stopwatch etc
#8 Posted : Monday, February 14, 2022 6:30:08 AM(UTC)
See https://forums.vmix.com/posts/m99770-Scripting-for-Dummies#post99770
