paulpfab
#1 Posted : Wednesday, February 9, 2022 10:48:13 PM(UTC)
paulpfab
Austria
hi all,
is it possible to change the presets (the lines i can add in tileditor) via midi?
i want to have ONE lower 3rd insert (i have to change the layout often) for names, using the same grafix but with different names out of the .csv-file, and change the entry via midi/shortcut.
thx in advance.
#2 Posted : Thursday, February 10, 2022 12:54:59 AM(UTC)
Originally Posted by: paulpfab Go to Quoted Post
hi all,
thx in advance.
PLS check using data sources and its related shortcut uptions that can be triggered with external controlers including Midi driven ones
check the helpfiles for "Controller Options"
paulpfab
#3 Posted : Thursday, February 10, 2022 3:29:40 AM(UTC)
paulpfab
Austria
Screenshot (2).jpg (151kb) downloaded 0 time(s). Screenshot (1).jpg (297kb) downloaded 0 time(s).
thx for your answer. i already found the datasource-thingy.
but i didnt find a working way to address a shortcut to a datasource-row. (screenshot2) i tried with and without path, with .csv and without.
#4 Posted : Thursday, February 10, 2022 4:01:09 AM(UTC)
you have to use the name of the table used in the data soure NOT refer to the file (you already did that in the settings )
Say you have multiple Excel files loaded you can rename each to be more practical and avoid refering to the first Excel/CSV one (as others having a duplicate name)
paulpfab
#5 Posted : Thursday, February 10, 2022 4:12:27 AM(UTC)
paulpfab
Austria
thx. that solves my problem.
