OmegaProductions
#1 Posted : Tuesday, February 8, 2022 12:47:57 PM(UTC)
OmegaProductions
Ok friends I need ADVISE.
I have a really nice VMIX rackmount setup with an RTX 3060 Graphics card in it. The Rackmount server case it installed inside a nice rack inside a road case that get loaded into a cargo trailer. We constantly have issues with having to Re-Seat the graphics card in order to get it working properly. I have put foam under the road case and everything is tight inside the rack. Does anyone have any advice on what else I could do to keep the graphics card in the PCI slot more secure? Thanks
VMix Ver 24.0.0.72
Mainboard - PRIME Z390-A
CPU - Intel Corei7-9700K (8cores)
32GB RAM - G.SKILL TridentZ Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600)
VIDEO - NVIDIA GeForce RTX 3060 - Driver Ver 472.12
Capture - BlackMagic Declink Quad 2
M.2 OS Drive
zenvideo
#2 Posted : Tuesday, February 8, 2022 8:12:41 PM(UTC)
zenvideo
That's surely a function of the rackmount case, as to whether it has adjustable retainers above the PCIe slots. Or are you saying it does have retainers, but they're simply not doing the job well enough? Maybe post a picture of the inside of the case (which would be more relevant than the spec of the PC)?
