Feature Requests
Add a MultiCorder-esque list to Additional NDI Outputs
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Right now, one can individually toggle NDI on/off for the 4 outputs.
Then are 2 additional NDI output toggles, 1 for cameras, calls, and audio inputs, and another for audio outputs. Both are all or nothing.
So if you need NDI outputs on, say, 2 non-output cameras out of 5 & 1 additional non-output audio bus, your only option is to turn on NDI for all of your audio buses & all of your cameras/calls/audio inputs. This adds strain to both the machine doing the encoding & the network. It's surprisingly easy to overwhelm your network with just NDI.
To combat this, I'd suggest a list similar to the one on the MultiCorder, where, instead of an all-or-nothing approach, you can pick the specific elements you need from the specified categories & spare yourself the overhead of including the ones you don't.
Feature Requests
