NDI
Vmix and ndi bridge on deck link quad duo at the same time
Hello. Anyone know if I can run vmix grubbing video from the deck link quad duo and at the same time use ndi bridge to share all the deck link inputs as ndi channels on the network?
The hardware access is exclusive from vmix?
Thank you.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Vmix can output all camera inputs as NDI
Originally Posted by: Henny  Vmix can output all camera inputs as NDI Only 4....
You have been a member since:: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: openaspace  Only 4.... Only 4 give you more fine tuned control by routing them to outputs & configuring the output NDI settings individually. There's also an all/nothing for cameras/calls/audio inputs.
Originally Posted by: WaltG12  Originally Posted by: openaspace  Only 4.... Only 4 give you more fine tuned control by routing them to outputs & configuring the output NDI settings individually. There's also an all/nothing for cameras/calls/audio inputs.
Do you have tried to use at the same time vmix and ndi bridge?
NDI
