hi all, i would need to recall presets on my onvif-ptz-cams.
its possible with this cmd "onvif-ptz goto-preset --baseUrl=http://x.x.x.x:8080 -u=xxx -p=xxx --preset=1"
how can i shoot this command in vmix? i would need it on a button on my midicontroller. or do i need an external app?
any ideas?
Joined: 3/7/2012(UTC) Posts: 2,673  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ paulpfab vMix does not support the ONVIF protocol with PTZ cameras: https://www.vmix.com/sof...ardware.aspx#ptz-camerasEssentially, the majority of cameras that use ONVIF only use a subset of control commands which are not accurate/precise enough for use with vMix Ice
